'weld' with sparks effect
jim bachalo
on Sep 15, 2011 at 3:20:51 pm
Hi
Can anyone tell me if the 'weld with sparks' effect
http://www.zacuto.com/bts-webisode-1
exactly 30 seconds in
is possible to do natively with AE, or do I need to purchase a plugin ie Particular?
Local is the new global
ben g unguren
Re: 'weld' with sparks effect
on Sep 15, 2011 at 3:32:02 pm
AE's "CC Particle World" plugin should give you what you're looking for. Here are a couple tutorials that should get you started:
http://www.videocopilot.net/tutorials/3d_sparks_title/
http://effectsportal.net/index.php/2-minute-tutorial-how-to-make-sparks-in-...
Ben Unguren
Motion Graphics & Editing
http://www.mostlydocumentary.com
Tudor "Ted" Jelescu
on Sep 15, 2011 at 4:38:31 pm
I've used CC Particle World to do thhis kind of effect and it worked great for me.
Tudor "Ted" Jelescu
Senior VFX Artist
jim bachalo
on Sep 15, 2011 at 5:09:42 pm
Thanks...will give it a try...will eventually get Particular but if I can save $400 for just this effect...
Raine Vivian
on Sep 15, 2011 at 7:44:52 pm
CC partical world should work fine. He the blend mode to add, and duplicate the layer a few times to add intensity.
-Raine Vivian
http://www.rainevivian.net
http://www.seaboundesign.com
Walter Soyka
on Sep 15, 2011 at 10:30:19 pm
[jim bachalo] "will eventually get Particular but if I can save $400 for just this effect..."
As the others said, CC Particle World will do this effect well.
That said, Particular is incredibly flexible, and you can use it for all sorts of effects that you might not think of at first. It's a great buy, and once you have it, you will find all sorts of uses for it. For example, see this recent thread where Marc De Coster is building an animated dandelion with Particular [link].
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
