Color Keying Problem
Mostafa Talebi
on Sep 14, 2011 at 8:24:03 pm
hello
I have done up to a some level for keying this movie. but I have problem to remove tracking marks and to remove the additive annoying color made upon the character marginal area.
shown in picture below:
Stefan Hinze
Re: Color Keying Problem
on Sep 14, 2011 at 9:27:13 pm
hey,
i think its a problem of the codec.
how ever, try this to solve the problem:
use the AlphaMask of the key and aply it to the duplicated footage (on the dulicate you dont need a keyer!)
dublicate the clip
keep the clips at the same time // synced
remove the key from the lower copy
set the lower clip to get the alpha from the upper one
if it dosnĀ“t work - precompose the upper one
hope this helps
stefan
ben g unguren
on Sep 14, 2011 at 9:35:48 pm
I concur with Stefan's suggestion. One addition: go ahead and use the key on the bottom layer, but tell it not to use the alpha. If you're using Keylight, there is a view setting called "Color Corrected Footage" -- this allows Keylight to remove all the spill, etc, but doesn't actually do any cutting. I suggest you use the simplest (that is, default-est) settings possible for this lower layer. The color problems you're experiencing are probably from the keyer trying to remove spill while simultaneously keying a substantial range of the image....
Ben Unguren
Motion Graphics & Editing
http://www.mostlydocumentary.com
Mostafa Talebi
on Sep 14, 2011 at 10:09:53 pm
Hey man Thank you
your solution got to work, but it continues to have a transparent green bg instead of a full transparent bg.
I'm using Primatte Keyer plugin.
In fact with key light plugin I go completely O.K with no cutting-in error and everything looks fine.
ben g unguren
on Sep 15, 2011 at 1:04:47 am
Sounds like keylight is the solution to use for this particular shot! Glad you got it to work.
Ben Unguren
Dave LaRonde
on Sep 14, 2011 at 9:37:31 pm
I can't tell which chroma keyer you are using. But it looks like you added too much magenta color to compensate for green spill light on the subject.
Dave LaRonde
Sr. Promotion Producer
