Time-travelling stutter when looping.
Ben Walker
on Sep 13, 2011 at 1:56:54 am
I've been trying to loop a robotic arm extending out and then retracting back in. It's a 2 second animation. However, on frame 01:24 there's a stutter that shows blurred movements for a split second of the arm that occurs neither in the frame before or after it - it's like it's jumping back even earlier in the timeline for a single frame and then loops the rest normally. The flicker is becoming quite distracting.
I'm relatively new to After Effects and I've been fiddling with this for days, scanning the forums and looking at tutorials and all sorts of things, but I just can't seem to fix it. I'm sure it's probably a simple solution and I'm just not understanding something basic about loops but I'm quickly running out of time and it still isn't working. Does anyone have any ideas?
I've (hopefully) attached an image detailing the problem: Image of loop error here.
Roland R. Kahlenberg
Re: Time-travelling stutter when looping.
on Sep 14, 2011 at 3:52:16 am
It's hard to tell what the cause is from the images you've provided.
I suggest the following -
1) Switch off Motion Blur to see if the issue still persists
2) Ensure that the last keyframes of both compositions are aligned in time.
Good Luck
Intensive AE & Mocha Training in Asia.
© 2018 All Rights Reserved
