White foamy mustache of a boat wake ...Form...
niccolo ungaro
on Aug 25, 2011 at 7:30:41 pm
How can I get a wash track of foam that follows a boat path .....?
Thank you all for your kind attention.
Nic.
Tudor "Ted" Jelescu
Re: White foamy mustache of a boat wake ...Form...
on Aug 25, 2011 at 8:24:26 pm
Are you referring to something like this:
Tudor "Ted" Jelescu
Senior VFX Artist
niccolo ungaro
on Aug 25, 2011 at 8:27:56 pm
Yes..!
Somthing like that...with more foam...
I wisch i could find som fractal nois preset... Or even better R.G. Form...preset or tutor....
Tudor "Ted" Jelescu
on Aug 25, 2011 at 8:34:35 pm
I did that using FreeForm Pro, but you can use the regular Free Form that comes with AE as well. The trick is to have a nice animated texture of water splashing (I used Particle illusion to create that)with a feathered alpha. Then you need to match the angle of the perspective and add some fractal texture on a 3d layer with a mask for extra foam in the water.
Tudor "Ted" Jelescu
Senior VFX Artist
niccolo ungaro
on Aug 25, 2011 at 8:41:28 pm
Grazie Ted,
I know that you are a magician with Free Form.
You Advanced 2.5D Animation in AE tutor is very nice & challenging.
I will give a try to your anwer.
Thanks.
Nic.
Tudor "Ted" Jelescu
on Aug 25, 2011 at 8:51:46 pm
Glad to hear that the stuff I put out there helps!
One other thing I did was to use Particular to create the foam around the tip of the warship in the clip below. I wish I had more time to play with it though.
Tudor "Ted" Jelescu
Senior VFX Artist
niccolo ungaro
on Aug 26, 2011 at 1:15:53 am
Nice very well dun thanks to share...although the sobject is not really my cup of tea.
niccolo ungaro
on Aug 25, 2011 at 8:24:38 pm
The sailing boat
http://f1.creativecow.net/2850/the-sailing-boat?uploaded=file
