suppressing specific colors WITHOUT using hue-sat control
jim bachalo
on Aug 17, 2011 at 6:58:19 pm
Hi
Listening to a great podcast with Peter Doyle, colorist for Harry Potter, where he explains he developed a set of matrices to suppress specific colors, similar to green screen suppression. But NOT the same as simply dialing down the saturation.
http://media.fxguide.com/fxpodcast/fxg-110803-PeterDoyle-HP7pt2.mp3
Can anyone suggest how you might do this in AE?
Local is the new global
Michael Szalapski
Re: suppressing specific colors WITHOUT using hue-sat control
on Aug 17, 2011 at 8:14:58 pm
Using the Hue/Sat control, you can isolate certain colors to desaturate. Poke around in it some more. (Specifically the channel control. Note that you can adjust it further beyond the basic drop down.)
That being said, you could also key them out and use the key as a track matte for an adjustment layer (among many other ways to control it).
Also, check out Synthetic Aperture's Color Finesse that comes with AE. It has a ton of very powerful color grading tools in it.
- The Great Szalam
Kevin Reiner
on Aug 18, 2011 at 9:15:22 pm
Change To Color and Change Color are good for a quick fix. Then I second Michael's suggestion of Color Finesse. You can also get somewhere with curves. Depends on what you're trying to accomplish.
Mac Pro 2 x 3 GHz 6-Core Intel Xeon
32GB Memory
Dual-channel 4Gb Fibre Channel PCI Express card
Dell Display (23" flat panel)
ATI Radeon HD 5770
AJA Kona LSi SD/HD capture card
Rourke 16 TB
Flanders 2460
SOFTWARE
Mac OS X 10.6.5
FCP 7
After Effects CS5
Boris Continuum
Sapphire Plug Ins
All Trapcode Plugs
Zaxwerks Invig
