Way to send footage to Mocha from after effects for ease when using Dynamic Link?
Nick Shaw
on Aug 16, 2011 at 12:34:53 am
I often use Dynamic Link between premiere and After Effects. So with that I am sending a segment of a whole clip to after effects rather that just editing the whole clip. My question is can I do this from After Effects to Mocha (just that segment) without having to render out that segment from after effects and then open it in mocha and track it? Because I dont want to import the whole orignal clip and track that
Todd Kopriva
Re: Way to send footage to Mocha from after effects for ease when using Dynamic Link?
on Aug 16, 2011 at 12:46:59 am
No.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Nick Shaw
on Aug 16, 2011 at 1:03:19 am
Well is there at least a workflow that can speed this process up? If I'm working on a 20 minute film with 40 different shots I have to track you're telling me I have to use dynamic link, export the clip, and put it into mocha every time? Is there no more efficient way?
Roland R. Kahlenberg
on Aug 16, 2011 at 4:43:06 am
As per Todd's reply, there is no dynamic link between Mocha and AE. Mocha needs a fully rendered file. What you can do is to import the entire original 20-minute clip into Mocha and use Mocha's Project In/Out points to define each of the 40 clips that you want to track in Mocha.
Further, each layer in Mocha can be defined into its own In/Out points relative to a project's In/Out points. It's up to you how you would like to track the 40 segments. I would separate them into groups of 5 tracks per project, just so that the Mocha project doesn't get too heavy.
You should also take note that importing a 20-minute clip will result in a long Cache time in Mocha. Therefore, I suggest that you store the 20-minute clip on a fast storage device and disable Mocha's Cache when importing the said clip.
HTH
RoRK
Intensive AE & Mocha Training in Asia.
