Project will not render - Any ideas?????
toby lakeman
on Aug 13, 2011 at 10:56:07 pm
I made animated a path and can not render it out.
I have worked with after effects for years and never had a problem rendering out a job. I have animated a path and attached a screenshot. Tried a quicktime animation, h264 and an avi can't get any picture. You can see the camera movement on the ground but no animated path.
If I render in the project you can see the path animate but render out a file and nothing very strange. Restarted computer checked all settings to no avail. Im on a fairly new Mac only a year old.
If anyone has any thought much appreciate a response.
Stefan Hinze
Re: Project will not render - Any ideas?????
on Aug 14, 2011 at 1:24:59 pm
(this goes more in the direction "did you turned on the computer"-hotline advice, but anyway)
is the camera you animated, set as the one AE should use to render?
is you footage set as a guide-layer?
try to precompose the whole thing and then check if you see the right camera.
(take a step back, to see the bigger picture)
toby lakeman
on Aug 14, 2011 at 10:56:54 pm
Thank you it was set as a guide layer. I have not used these before but that was the problem cheers again.
© 2018 All Rights Reserved
