particular not following pasted illustrator masks
Heather Crank
on Aug 13, 2011 at 3:29:09 am
Hello Everyone,
I have an illustrator logo with outlined font that I would like to reveal with a particular light streak in AE. When I copy the path from illustrator into the position property of the particular emitter nothing happens. I can paste the mask from the font into the position property of a solid. I must be missing a step. Anyone know what I'm doing incorrectly?
H
Brian Charles
Re: particular not following pasted illustrator masks
on Aug 13, 2011 at 9:54:25 pm
When you paste the path to the emitter do you see Roving Keyframes?
Is your path too small to register? Turn Directional Spread and Velocity Distrubution to 0.
Heather Crank
on Aug 13, 2011 at 10:59:58 pm
Duh,
Did something really dumb, was clicking on the mask layer instead of twirling down the mask and copying from the mask "position".
You don't happen to know how to keep a light emitter from affecting other elements in the comp do you?
H
Brian Charles
on Aug 14, 2011 at 12:28:32 am
You can set the light intensity to 0 and in Particular change the Particles/sec modifier from Light Intensity to None, then use the regular Particles/sec property under Emitter.
Heather Crank
on Aug 14, 2011 at 12:35:34 am
Thanks Brian!
Michael Szalapski
on Aug 14, 2011 at 1:07:57 am
Turn off the eyeball on it.
- The Great Szalam
