Nuke camera to After Effect..... ??
niccolo ungaro
on Aug 9, 2011 at 11:55:42 pm
I will like to export all camera data from Nuke to After Effect...any suggestion???
Thank you & regards.
Nic.
Tudor "Ted" Jelescu
Re: Nuke camera to After Effect..... ??
on Aug 10, 2011 at 10:40:17 am
Not sure if a straight export is possible, but you could use Camera Tracker from The Foundry in AE to extract cam data from a rendered clip in Nuke. It's a work around, I know, but is the only idea I have- maybe someone else can give you a better solution.
Tudor "Ted" Jelescu
Senior VFX Artist
Darby Edelen
on Aug 10, 2011 at 5:33:02 pm
As far as I know the only way to export camera data out of Nuke is in a .chan file. Maya can open that, and then you can save the scene as a .ma file that AE should be able to import.
You may run into some issues with frame sizes and unit conversions, but that's the closest I can come up with off the top of my head.
Darby Edelen
Tudor "Ted" Jelescu
on Aug 10, 2011 at 6:38:35 pm
Elegant option- did not think of that one.
Tudor "Ted" Jelescu
Senior VFX Artist
niccolo ungaro
on Aug 11, 2011 at 3:41:12 pm
Thank you all.
Grazie mille ragazzi!
