XYZ Axis manipulator size.
Aaron Lenius
on Aug 4, 2011 at 6:55:48 pm
How can I change the size/scale of he XYZ manipulator in the After Effects composition window? when you zoom out in a 3D comp to see more of your elements those manipulators get super tiny.
Thx
Aaron
Dave LaRonde
Re: XYZ Axis manipulator size.
on Aug 4, 2011 at 7:47:07 pm
You don't do it directly. It's done by opening another view -- AE allows multiple viewers:
http://help.adobe.com/en_US/aftereffects/cs/using/WSCF40A9D1-B832-4bc8-B4B2...
In the second viewer, you'd adjust a different view choice to allow you to see the big 3D picture while you use the layer's XYZ manipulators.
Dave LaRonde
Sr. Promotion Producer
Walter Soyka
on Aug 4, 2011 at 8:06:53 pm
[Dave LaRonde] "You don't do it directly. It's done by opening another view -- AE allows multiple viewers... In the second viewer, you'd adjust a different view choice to allow you to see the big 3D picture while you use the layer's XYZ manipulators."
Nice tip, Dave!
Please allow me to add to it: leave your big picture view on active camera and use a custom or orthographic view for your up-close view. With the camera tool active, tap the F key to make the custom view's camera look at the selected 3D layers. (With any other tool active, you have to press Cmd-Opt-Shift-\ (Mac) or Ctrl-Alt-Shift-\ (PC), which requires significantly more advanced dexterity.)
Of course, you could also just scrub the X, Y, or Z values in the Position property in the timeline.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Dave LaRonde
on Aug 5, 2011 at 3:41:20 pm
[Walter Soyka] "Of course, you could also just scrub the X, Y, or Z values in the Position property in the timeline."
That's how I'd do it!
Dave LaRonde
