Illustrator clipping path causing problems in AE
Dan Fredley
on Aug 4, 2011 at 2:35:57 am
This has happened in several projects on different illustrator files where there is a raster image embedded in an illustrator file and a clipping mask is applied. In AE the clipping mask causes the raster image to wiggle. Any way around this besides exporting the raster image and masking it in AE?
Thanks.
Dan Fredley
Michael Wilfong
Re: Illustrator clipping path causing problems in AE
on Oct 31, 2011 at 7:43:19 pm
I would love to know the answer to this, as well. I have a huge illustrator file with around 120 images (all with clipping paths) that need to be animated in AE. Any help would be much appreciated.
m.
Using CS 5.5
