Need a tip on changing AE comp size
scott sullivan
on Aug 3, 2011 at 9:36:11 pm
Hi
I have an AE template I want to use in Full HD, 1920 x 1080 px - but I need to render and get it over to a Sony Vegas 720x480 project.
what should I do to change the AE template size? If i just change the comp settings in AE, the video zooms in too much and the text doesn't display properly (its off screen).
Any ideas?
Michael Szalapski
Re: Need a tip on changing AE comp size
on Aug 3, 2011 at 9:40:52 pm
Nest that comp in the smaller comp and resize it.
- The Great Szalam
scott sullivan
on Aug 3, 2011 at 9:52:06 pm
awesome and simple - thanks!
Dave LaRonde
on Aug 3, 2011 at 9:49:34 pm
Michael's right about nesting the big comp in a small comp.
If the video is to remain 16x9, use the NTSC DV Widescreen comp preset, nest the comp in it. Use the Command-Option-f keyboard shortcut to perfectly fit the larger comp into the smaller comp.
If the video needs to be 4x3, you can either center-punch or letterbox, depending on what's required. In either case, use the NTSC DV comp preset -- not the widescreen one. then you can scale the nested layer to 100% of the comp's width for letterbox, or 100% of the comp's height for center-punch. I haven't memorized the keyboard shortcuts for doing them.
Dave LaRonde
Sr. Promotion Producer
scott sullivan
on Aug 3, 2011 at 9:55:08 pm
thanks to you both - this simple tip helps me a lot!
niccolo ungaro
on Aug 4, 2011 at 8:45:55 am
One word....Sir Mr.Andrew !!! o Videocopilot + preset.
http://www.videocopilot.net/presets/aspect_ratio_letterbox/
