After Effects won't hide under Mac OSX Lion
Lance Moody
on Aug 3, 2011 at 2:10:59 am
Anyone else seeing this behavior?
Hide AE does not work. The AE windows stay onscreen.
The hide command does deactivate AE--clicking on an AE window does not bring the app to the foreground but it doesn't actually hide it.
Lance
Galen Fott
Re: After Effects won't hide under Mac OSX Lion
on Aug 3, 2011 at 3:49:30 pm
Ditto here. Annoying. I'm using CS5. You?
Dave LaRonde
on Aug 3, 2011 at 4:17:16 pm
Sounds like you gents could benefit from a visit here:
http://forums.adobe.com/thread/879748?tstart=0
Check out the links & join the thread if you'd like. But look at the links first.
Dave LaRonde
Sr. Promotion Producer
Lance Moody
on Aug 3, 2011 at 5:08:07 pm
Thanks Dave,
Yes, I read that document when it came out. It does not mention this issue, unless I missed something. Did you see something specifically referencing the issue somewhere?
Lance
P.S. I am using CS 5.5.
Dave LaRonde
on Aug 3, 2011 at 5:15:26 pm
[Lance Moody] "Did you see something specifically referencing the issue somewhere?"
Did you look at all the links? If you did and you're still having problems, those are the guys to ask. Just join the thread. They'll have an answer faster than what you'd get here.
Personally, I have not yet installed AE 10.5.
Dave LaRonde
Todd Kopriva
on Aug 15, 2011 at 8:03:55 pm
What version, Lance? CS5? CS5.5?
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Adam Kois
on Oct 10, 2011 at 7:17:07 pm
I have the same problem. Installed java thing too. also i have found that sometimes the little red target won't appear for example if you are in the pan-behind tool, or a ramp expression. It only happens sometimes... weird
Robinson Sampaio
on Nov 27, 2011 at 6:37:47 pm
Same here. Lion 10.7.2 with CS 5.5.
And sometimes, the windows stay on top of any other application. Really weird.
Mark Warner
on Dec 7, 2011 at 4:01:49 pm
It seems to be strangely attached to the CAPS Lock key. If you try to hide AE and it doesn't, I find turning caps-lock on and off does the trick!
Robinson Sampaio
on Dec 9, 2011 at 1:21:07 pm
I tried it here, right now, and the problem persists...
But this time, the AE doesn't hide but the windows are behind all the other applications.
James Kecskes
on Apr 18, 2012 at 8:37:12 pm
Same problems here. Caps didn't work. How annoying.
Dave Harrison
on May 23, 2012 at 4:13:28 pm
It appears that when you Option-Click (on a Mac) the Desktop *then* hit the Caps Lock, After Effects will hide.
AE 10.5.0.253, Mac OS 10.7.2
--Dave
