Confining Trapcode Particles
Tristan Nieto
on Aug 2, 2011 at 9:56:26 am
Is there anyway to restrict particles to a specific area, either using a mask or an alpha matte or something? I can't just mask or matte it because that cuts through particles along the edges, which isn't going to work for me.
Not sure if it's even possible,
Tristan Nieto
Visual Effects & Motion Graphics
tristannieto.blogspot.com
Kevin Camp
Re: Confining Trapcode Particles
on Aug 2, 2011 at 4:56:53 pm
you can use air resistance (in physics>air) to slow the particles to a stop, if that's what you need... but i can't think of a way to fully contain them otherwise.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Darby Edelen
on Aug 2, 2011 at 9:03:22 pm
If you set the Physics mode to "Bounce" then you can use a floor and wall layer to contain particles, but you won't have access to the "Air" physics attributes.
If you need fine control over where the particles travel then I recommend using the Motion Path feature in the Air physics mode.
Darby Edelen
