AE CS5.5 vegas effect only works on curves!
Jiri Fiala
on Aug 1, 2011 at 10:53:29 am
Hi!
I don't know what I'm doing wrong, but the Vegas effect in AE CS5.5 only works on curved masks for me. If I paint a straight line (whatever angle), the effect doesn't render. When I change the same mask to whatever curve, it renders. I DO have selected the right mask.
What gives? Thanks!
Roland R. Kahlenberg
Re: AE CS5.5 vegas effect only works on curves!
on Aug 1, 2011 at 12:03:03 pm
Use a straight-lined mask BUT with at least 3 vertices.
HTH
RoRK
Intensive AE & Mocha Training in Asia.
Jiri Fiala
on Aug 1, 2011 at 4:56:58 pm
No, sorry, that doesn't work. Only curves. Really :-o
on Aug 2, 2011 at 2:22:39 am
Try this with a straight line mask with two vertices -
1) select the vertex that defines the end of the line
2) select the (G)raphic Pen Tool and click AWAY from the original line you intend to have. Ensure that this additional vertex is at an obtuse angle to the last vertex and only slightly away, in distance.
Vegas should now draw itself, defined by the first two vertices that you drew.
So, ermmm, technically, YES. Vegas does draw straight lines. :D
HTH
RoRK
Jiri Fiala
on Aug 5, 2011 at 12:06:06 pm
Yes Roland, your way works. One has to wonder how a bug like this comes to be :)
Thanks.
