Problem In After Effects CS5 with Rendering
Daniel Feivor
on Aug 1, 2011 at 1:17:48 am
OK, so I have been using after effects fine for about a month, but today I tried to render out a video that I had roto-brushed and when I went back to open it, the video was black. I tried changing some render settings, using AVI and Quicktime, with only RBG and with RBG plus Alpha, and I switched between straight and pre-multiplied, but nothing seems to help, any thoughts or suggestions?
Michael Szalapski
Re: Problem In After Effects CS5 with Rendering
on Aug 2, 2011 at 9:53:04 pm
Did you freeze your Roto Brush before rendering?
- The Great Szalam
Daniel Feivor
on Aug 3, 2011 at 4:11:46 pm
I don't know what you mean by freezing the roto-brush, but no worries. I went back and re-did the clip and after that it rendered fine, thanks though.
Michael Szalapski
on Aug 3, 2011 at 5:44:25 pm
You don't know about freezing it? Then you should definitely go through some of the resources here: [link] It'll help you work with the Roto Brush a lot better.
- The Great Szalam
Daniel Feivor
on Aug 9, 2011 at 11:36:07 am
Ahh, thanks, now I know a bit more about roto-brush, I guess thats what i get for trying to figure it out myself!
Michael Szalapski
on Aug 9, 2011 at 8:59:46 pm
It's not as intuitive as one might think.
Neither is After Effects. You say you've only been working with it for a month? Then let me point you to this: [link] It's a bunch of (free!) resources for those just starting out in AE, like you. If you don't have a good grasp of the foundation of AE, you can end up frustrated. I would also highly recommend this: [link] It costs about as much as a new video game, so it's not bad, but it gives you a lot more of an in-depth look at AE. Perfect way to start off, I think.
- The Great Szalam
Daniel Feivor
on Aug 10, 2011 at 2:06:13 am
Thanks! I'll definitely take a look at those
