Getting same error after ram previeuw
Anilio Sweet
on Jul 31, 2011 at 12:56:35 pm
Hi every one,
I had a question, i am getting the same and same error from after effects after ram a previeuw.
The message says:
after effects error: All backgrounds processes have terminated
So i googled it and i found a solving problem, someone suggest me to disable the multi proccesor, so i did, and that fixed te isseu, but i am wondering why??????
I know that i have a minor laptob for working on my afx CS4 and i have 4 gb ram in it but it only want to use 2gb it says, and i have a dual core 1.6ghz labtop
But if i turn out the Multi prosessor it says it only wil you 1.25 GB of ram and thats slowing thing real down ( it already was wit 2 gb but this is much more ) but the problem is solved but not on a way i wanted??
Does someone has a another sollution??
Todd Kopriva
Re: Getting same error after ram previeuw
on Jul 31, 2011 at 4:44:58 pm
You don't have enough RAM to use Render Multiple Frames Simultaneously multiprocessing.
You also seem to have a 32-bit operating system, so even if you had more RAM, you wouldn't be able to use it.
Get more RAM and upgrade to a 64-bit operating system.
See this page for information about memory and improving performance in After Effects.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Anilio Sweet
on Jul 31, 2011 at 5:34:52 pm
Thanks Tod,
Like always :):)
I know but upgrading wouldnt help because laptop only sees max 4 gb.
Puting a windows 64 bit on it wouldnt help, because there still wouldnt be a maximum of 4gb that i can put in the Laptob
That is my problem, soo your help cant help me!!
Todd Kopriva
on Jul 31, 2011 at 5:53:48 pm
Then just heed my first sentence. You can't use Render Multiple Frames Simultaneously multiprocessing with that system.
