RotoBrush Bug?
lee kessler
RotoBrush Bug?
on Jul 26, 2011 at 7:49:33 pm
Hey Everyeone, I am a veteran AE user and was experimenting with the new Rotobrush tool. I usually do frame by frame rotoscoping but wanted to give this a shot.
I am having an issue where I paint an area to ADD to the selection but the pink outline will not move. It seems like the area I paint is only effected in the next frame. also the "Span keyframe" (not sure what to call them, I am referring to the keyframes within a "span" area) are not masked. the frame before and after are masked, but the actual frame that the "span keyframe" is on, does not contain a mask.
If I am not clear please let me know, i will try to expand further.
Todd Kopriva
Re: RotoBrush Bug?
on Jul 27, 2011 at 12:46:25 am
You really need to watch the tutorials and read the documentation first. Trying to use the Roto Brush tool without doing so is certain to cause frustration and confusion.
http://blogs.adobe.com/toddkopriva/2010/04/roto-brush-in-after-effects-cs.h...
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
lee kessler
Re: RotoBrush Bug?
on Jul 27, 2011 at 3:33:28 am
i have read it, and im VERY comfortable with after effects so using the roto tool is kind of second nature. The problem i am describing is a little deeper than that thin "documentation"
Hinny Tran
Re: RotoBrush Bug?
on Feb 1, 2013 at 6:40:08 am
Yes My pink outline has stopped moving as well. It was working fine last night and now it's not. Let me know if you find a solution to this. Cheers!
