Disapparate Effects-Harry Potter
David Reese
on Jul 24, 2011 at 4:30:28 am
I would like to recreate the exact same look as seen in this clip from youtube.
I understand it won't look EXACTLY the same.
Would After Effects alone do this?
What all must be done camera wise?
Foot Work?
PS The effect is around 1:02
Tudor "Ted" Jelescu
Re: Disapparate Effects-Harry Potter
on Jul 24, 2011 at 11:38:41 am
If you want a steady shot like your example then it's fairly easy. You can either shoot the actors on chroma and then comp them in or shoot a clean plate (my choice- the set without actors). Either way you can isolate the actors with chroma keying or a difference key and then use Mesh Warp to distort them to disappear in a point. The trick will be to use the bezier handles on the mesh to create a smooth organic move. Things like blur (radial set on spin) and glow and maybe Trapcode Shine may add something to the effect.
Tudor "Ted" Jelescu
Senior VFX Artist
Christiaan van EIjk
on Aug 2, 2011 at 5:28:29 pm
Hello David Reese,
As 'Tudor' already said: ''With a steady shot like this it is very easy to create this effect''.
basic steps
1. Get a camcorder on a tripod
2. Make sure that you get a clean plate of your background
3. then just add smoke, a certain blur effect(s) and some distortion
4. to make the effect look a bit more realistic, create some
visual camera movement
i am bysy making a video-tutorial about this effect. as soon i`m finished i will send you a message for that
David Reese
on Aug 13, 2011 at 4:34:30 pm
How is the tutorial coming along?
