Is there a shortcut to extending Comp to match footage layer?
Sean Worsell
on Jul 24, 2011 at 2:24:23 am
I find this one comes up a lot for me. After you have created your first comp in a project, AE remembers the comp length so any new comps are of the same length. So you drop your next footage layer into this new comp...but the comp isn't long enough. It was the right length for the last footage you worked with, but too short for the new one. Is there a quick and easy shortcut (maybe even a script) to "extend comp to match layer" so that the comp then becomes the same length as the footage layer?
Michael Szalapski
Re: Is there a shortcut to extending Comp to match footage layer?
on Aug 2, 2011 at 8:55:40 pm
Just drag your footage onto the make new comp button.
- The Great Szalam
