Roto Brush Frame Mismatch
Adam Hark
on Jul 21, 2011 at 8:27:30 pm
Ok, so I have some footage that is from a digital system where everything is DVCPRO50, 29.97. I bring it into After Effects CS 5.5 and drag it to the "Create a New Composition" button. It creates a Comp at 720 by 480, widescreen pixel aspect, 29.97 frames per second. This is exactly what the clip is. As soon as I use the roto brush on this clip, I get the error message, Frame Rate Mismatch, For Best Roto Brush Results, set the composition to 59.94 fps to match layer source. This makes no sense since After Effects just used the settings of the clip to make a 29.97 composition. Why would I switch to 59.94 when the clip is not? Here is a link to someone else that is having the same problem:
http://forums.adobe.com/thread/686986
Anyone having this issue or have a clue how to fix it? Does the Roto Brush only work at 59.94?
Thank You
"We'll Fix it in Post."
Dave LaRonde
Re: Roto Brush Frame Mismatch
on Jul 21, 2011 at 10:04:54 pm
I see you chose to ignore the advice given by Adobe Employees and seasoned AE veterans contained in that thread. Any reason why?
Dave LaRonde
Sr. Promotion Producer
Barend Onneweer
on Jul 22, 2011 at 6:40:12 am
If the footage is interlaced it's usually better to do masking work on the individual fields - hence the advise to set the comp to double framerate so the individual fields are exposed.
Barend
Raamw3rk - digital storytelling and visual effects
