Video output error
sunil kajal
Video output error
on Jul 15, 2011 at 9:38:45 am
Hi frnds, this is my first post here.
i am using Adobe after effects 7.0 pro. i am just learning it nowadayz. it was working perfectly initialy but now wenever i render the project the outout is very distorted and grainy and black and white.. its so frustrating bcoz after waiting fr so much time to render i get a damaged output :( i hav tried differents formats of outputs and different variables but it doesnt help.
these are the snapshots of the original verion inside after effects and the damaged output version of output video.
Original version
Damaged video output
the output file is damaged as shown in image and it plays like this only.. i Hope i will get a solution for this fast. thnxx in advance :)
Dave LaRonde
Re: Video output error
on Jul 15, 2011 at 1:19:28 pm
After Effects Version SEVEN? Really? Here's the most likely explanation for your problem:
Dave's Stock Answer #1:
If the footage you imported into AE is any kind of the following -- footage in an HDV acquisition codec, MPEG1, MPEG2, AVCHD, mp4, mts, m2t, H.261 or H.264 -- you need to convert it to a different codec.
These kinds of footage use temporal, or interframe compression. They have keyframes at regular intervals, containing complete frame information. However, the frames in between do NOT have complete information. Interframe codecs toss out duplicated information.
In order to maintain peak rendering efficiency, AE needs complete information for each and every frame. But because these kinds of footage contain only partial information, AE freaks out, resulting in a wide variety of problems.
I'm a Mac guy, so I like to convert to Quicktime movies in the Animation or PNG codecs; both are lossless. I'll use Apple's Compressor, Adobe Media Encoder or Quicktime Pro to do it.
Dave LaRonde
Sr. Promotion Producer
sunil kajal
on Jul 15, 2011 at 5:52:46 pm
thanks sir for your quick reply.
actually am currently working on a dell mini laptop, which unfortunately supports the AE 7.0 or previous versions only :(
i hav not imported any video into the AE, i hav imported some .psd file and some image files to create a 3D building and its environment. so when i render it in .avi or .wmv format it creates such damaged output. i was sucessful only once when i kept the output file as a .wmv file and resolution at one by third and also reduced the frame rate. but after tht i hav tried many combinations but same damaged output.
