Q about Stablizing Video
Clint Milner
on Jul 11, 2011 at 1:28:48 pm
I have a shot of some hand held footage that I've successfully stabilized using AE CS4. But now I have this bouncing frame moving all over the comp and now I'm in the process of animating the scale and X/Y position to keep the stable video in frame.
But I was wondering if some AE Guru out there has devised a script or plug-in to do this automatically?
Thanks all,
Clint
Adobe CS4 Master Suite
Vista Ultimate 64 SP1
Intel Core i7 920 @ 3.60GHz
12 GB DDR3 RAM
NVidia Quadro FX 3700
Matrox RT.X2 LE Capture Card
4 TB RAID 5
Dave LaRonde
Re: Q about Stablizing Video
on Jul 11, 2011 at 2:06:07 pm
Actually, Adobe developed something called Warp Stabilizer. It's in AE 10.5. The amount of success with it varies with the severity of the extraneous motion.
Dave LaRonde
Sr. Promotion Producer
Clint Milner
on Jul 11, 2011 at 2:26:49 pm
Hi Dave,
Thanks for the info, I wish I could upgrade to CS5.5 right now, Warp Stabilizer looks like something I could use a lot with hand-held footage.
I'm guessing there's not a solution for CS4...
Clint
12 GB DDR3 RAM
4 TB RAID 5
Dave LaRonde
on Jul 11, 2011 at 2:39:04 pm
Not really. AE 9's stabilization works like all the previous versions.
It's very difficult to shoot hand-held and NOT get the random motions inherent in hand-held. As always, if the look of hand-held isn't desirable, it's necessary to use primary motion stabilization: a tripod.
Dave LaRonde
Brian Charles
on Jul 11, 2011 at 2:59:54 pm
[Dave LaRonde] "As always, if the look of hand-held isn't desirable, it's necessary to use primary motion stabilization: a tripod."
Words of wisdom.
Walter Soyka
on Jul 11, 2011 at 4:48:26 pm
[Clint Milner] "I have a shot of some hand held footage that I've successfully stabilized using AE CS4. But now I have this bouncing frame moving all over the comp and now I'm in the process of animating the scale and X/Y position to keep the stable video in frame."
This workflow will de-stabilize your video -- you've removed the hand-held camera motion, but now you're re-introducing motion and scaling to avoid cropping the frame.
If you want a solid shot, you're better off finding the worst post-stabilization frame, then adjusting the scale up until the video layer is no longer cropped. The idea is to find one scale/position value that fixes the entire shot.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Clint Milner
on Jul 12, 2011 at 9:33:02 am
Thanks Walter, I'll remember that in the future... this is some just some wedding speeches for a friend, so it's not professional at all. I think I've lucked out a bit because it was shot with an HD camera, and I'm delivering on DVD, so most the noticeable movement has been fixed by doing this manually.
Thanks everyone.
12 GB DDR3 RAM
4 TB RAID 5
