Error: Photoshop library operation failed because of a program error
Randy McWilson
on Jul 8, 2011 at 1:41:19 pm
When I try to import a 3D Photoshop file into After Effects 5.5 it throws up the error "photoshop library operation failed because of a program error" when it tries to draw the composition. I have 4GB ram, and the 3D object has about 300,000 polygons.
My video card does not support Open GL.
Any ideas anyone?
thanks
Randy
Eternity...don't miss it for the world.
Dave LaRonde
Re: Error: Photoshop library operation failed because of a program error
on Jul 8, 2011 at 1:47:49 pm
[Randy McWilson] "After Effects 5.5... I have 4GB ram..."
Holy cow! 4GB may seem like a lot to you, but it's almost nothing to AE. Using multiprocessing is the most common problem with this amount of memory; if you have it turned on, turn it off right now and leave it off until you get something in the neighborhood of 16 gigs.
Dave LaRonde
Sr. Promotion Producer
Todd Kopriva
on Jul 8, 2011 at 5:49:04 pm
The Photoshop 3D feature in After Effects is a memory hog and it requires OpenGL to work without being maddeningly slow. So, if you are trying to use a high-polygon-count 3D object through this feature on that computer, you are going to have problems.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
