Render layered photoshop sequence
Neil Anderson
on Jun 28, 2011 at 9:03:14 pm
Is there any way to render a photoshop sequence with layers?
I want to run a photoshop action on all the frames in a clip, but require a mask layer. Since AFAIK photoshop actions can't grab the mask from another file (in an automated way) I need to have the mask for each frame available in the same PSD file on a different layer.
The filmstrip format would also make this possible, but I can't seem to find that in the output modules.
Walter Soyka
Re: Render layered photoshop sequence
on Jun 29, 2011 at 1:24:16 am
[Neil Anderson] "Is there any way to render a photoshop sequence with layers?"
Not that I know of. This would be a great feature request [link], though.
[Neil Anderson] "I want to run a photoshop action on all the frames in a clip, but require a mask layer. Since AFAIK photoshop actions can't grab the mask from another file (in an automated way) I need to have the mask for each frame available in the same PSD file on a different layer."
Perhaps you can accomplish what you need with Photoshop Extended's video layers [link]?
[Neil Anderson] "The filmstrip format would also make this possible, but I can't seem to find that in the output modules."
Filmstrip has been deprecated.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Neil Anderson
on Jun 29, 2011 at 4:51:37 am
Thanks. I did end up using photoshop's video layers. I hadn't realized you could import more than one of them into a document.
