duplicate particle layer problem
Esteban Bustos
on Jun 14, 2011 at 10:10:20 pm
why when i duplicate a particular layer it changes the position of other layers(also particular)... its weird. helpplease
Alex Brown
Re: duplicate particle layer problem
on Jun 15, 2011 at 12:22:43 am
Sounds like you may have an expression on the position property inside of particular? When you do that and you duplicate a layer, particular takes the random seed from the layer order, so the 2nd layer will be in a different position.
A better solution is to create a null object and then alt-click on the position inside Particular and pick whip the position to the position of the null object. You can then move the null around with an expression as before but when you duplicate your particular layer, it will stay in the same spot.
At least that's a fix if I understand your problem correctly?
Esteban Bustos
on Jun 15, 2011 at 2:29:43 am
yeah i created the null object, atched them the layer with particular ( several by the way), but maybe ur right with the random seed, maybe it's that it is pickedwhip to a null obj for sure.
