Can't undo in after effect
Rja Alfian
on Jun 11, 2011 at 9:46:54 am
Halo everyone,
I need help! Suddenly i can't undo my work in after affect cs5 mac.
When i click undo, its always appear; CHANGE VALUE in right side pallete.
Im a beginner, so i really dont have any idea what to do to fix it.
Thanks for any help and fast response..
Todd Kopriva
Re: Can't undo in after effect
on Jun 11, 2011 at 8:16:52 pm
I'm not clear on what you're saying.
Are you saying that pressing Ctrl+Z (or Command+Z on Mac OS) isn't undoing your most recent action?
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Rja Alfian
on Jun 11, 2011 at 10:17:56 pm
Yes absolutely right.
I can't undo just in one project i'm working on. Command z and undo button is not work. But if i open the new project with new comp, everything fine.
I already try to copy my 'can't undo' comp to new comp but also did't help.
Carlos Fernandez
on Jun 22, 2011 at 5:53:50 pm
I have the same problem. Are you using Trapcode Form? Try disabling it.
Jeremy Allen
on Jul 7, 2011 at 5:44:13 pm
I've just started using Form and I'm having the same problem. If I turn off the form layer, I can undo. And as Rja said, when form is enabled, all my undo history says is "Change Value" no matter what actions I actually completed.
Also, when I hit undo, I get a quick little render bar like its doing something, but nothing changes.
8core MacPro, 3.0 GHZ, 18GB RAM, OSX 10.5.8
C4D 11.5
AE CS5 (10.0.2.4)
FCP 7.0.3
QT 7.6.4
Todd Kopriva
on Jul 7, 2011 at 5:50:03 pm
It would be a good idea for you to submit a bug regarding Trapcode Form to the makers of that plug-in.
