Removing a dead pixel
Derek Bowshier
on Jun 9, 2011 at 2:07:59 am
I recently found that my canon 5dmark II has a dead/hot pixel.
I didn't notice it until I began reviewing some footage, where it is quite noticeable on quite a bit of the footage when the iso was up.
The footage is rather important and not something I can just re-shoot.
What would be the most efficient method in AE to remove the pixal?
I thought I read somewhere about a method that will automatically fill in the pixel based on the surrounding pixels?
Thanks.
Todd Kopriva
Re: Removing a dead pixel
on Jun 9, 2011 at 6:25:49 am
A few ways spring to mind:
You could use the CC Wire Removal effect.
Or you could adapt this technique:
http://blogs.adobe.com/sforde/2011/06/01/warp-stabilizre-redux/
Or you could use the Clone Stamp tool.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Tudor "Ted" Jelescu
on Jun 9, 2011 at 6:29:54 am
Or you can poke a hole through your layer using a mask, comp it on top of itself and shift 1-2 pixels (the direction depends on the shapes in the footage)
Tudor "Ted" Jelescu
Senior VFX Artist
Marc Nibor
on Jun 9, 2011 at 11:13:59 am
>>Or you can poke a hole through your layer using a mask, comp it on >>top of itself and shift 1-2 pixels (the direction depends on the >>shapes in the footage)
what a great idea!!
