text from motion with transparent background to after effects
Carlo Oller
on Jun 1, 2011 at 6:43:40 pm
Hello,
I just created an animated text in motion and exported it with a transparent background using the animation codec. My question is, how do I get that transparent background in after effects. once i import the video into AE, it imports with a blak background. how would I get the transparent background again?
Thank You,
Carlos O
Brian Charles
Re: text from motion with transparent background to after effects
on Jun 1, 2011 at 7:12:38 pm
If you rendered ad RGBA the alpha (A) is preserved, check the transparency switch in the Comp viewer.
http://help.adobe.com/en_US/aftereffects/cs/using/WS08A8A927-0E3A-48a6-AFF9...
Dave LaRonde
on Jun 1, 2011 at 7:55:07 pm
...which leads both the Good Mr. Charles and myself to believe that you might have not exported from Motion with that transparency.
I can think of two things that could have happened: you didn't know HOW to export from Motion with transparency, or you didn't have a transparent background in Motion.
Dave LaRonde
Sr. Promotion Producer
Carlo Oller
on Jun 1, 2011 at 8:02:34 pm
Hello,
I had the transparent background in motion before exporting it and had the codec settings in animation. I still wasn't clear if that was the right exporting settings, but it worked fine in FCP. I am new to AE, so i don't know what to do with the clip once its on AE.
Carlos O.
Dave LaRonde
on Jun 1, 2011 at 8:12:49 pm
An alpha channel is an alpha channel. If After Effects can't read it, I suspect you didn't look at the exported clip in FCP, but instead you imported the Motion project file into FCP... which is a very different thing indeed from an exported clip.
Dave LaRonde
