keyframe problems!
Ben Black
keyframe problems!
on May 31, 2011 at 12:15:56 pm
see photo
When i add in keyframes (with no ease added) for this cog after it has moved in towards the stairs and stopped, it keeps ADDING in/ making an arch movement between these. I want it to just stop normally and then move to the next without this extra movement added.
any help is much appreciated.
CHEERS.
Tudor "Ted" Jelescu
Re: keyframe problems!
on May 31, 2011 at 2:30:20 pm
No photo attached or link.
You problem comes from the way the interpolation is set as default for the keyframes. Choose linear or break the points on the path.
http://help.adobe.com/en_US/aftereffects/cs/using/WS3878526689cb91655866c11...
Tudor "Ted" Jelescu
Senior VFX Artist
