Keyframe Problem
Christopher Mallan
Keyframe Problem
on May 29, 2011 at 5:36:11 pm
i am doing some really basic animation which involves moving an object from one side of the screen to the other, pausing for a second, then moving again. I havent always had this problem but when i want it to pause, i set a key frame one frame before the point where i want the object to move again and set it as the same values as when the image first paused, leaving it at the same point for x amount of frames. for some reason in the time that the image is paused the values alter as if they have a mind of their own and then return to the original value. is there a setting or something i should be aware of?
many thanks
Chris
Kevin Camp
Re: Keyframe Problem
on May 29, 2011 at 6:19:31 pm
The issue is referred to as the boomerang effect. Aharon rabinowitz has a tutorial covering it, if you want to search the cow's tutorials...
To fix it, try selecting the keyframes, then choose animation>keyframe interpolation and set the spacial interpolation to linear.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Todd Kopriva
on May 29, 2011 at 6:48:00 pm
There's more information here, including a link to the video from Aharon that Kevin mentioned.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Christopher Mallan
on May 30, 2011 at 9:02:04 am
Great. Thought it would be something simple. Thanks for the swift reply!
Chris
Roland R. Kahlenberg
on May 30, 2011 at 10:17:21 am
All good solutions there BUT, the way you're going about creating a pause is not the right way. The proper way to create pauses is to use the Hold keyframe. Check the links that Todd provided.
Cheers
RoRK
AE Training in South East Asia. AE templates for sale and rental. Click here for more
