Match a 2d comp null position with a 3d space comp null position.
Ismael Vega Trillo
on May 24, 2011 at 9:15:37 am
I'm stuck with this!
Firstly, let me thank you in advance.
Well, here is my problem. I've a null (Null-1) object into a 2d space composition (CompA).
This CompA is, as well, a 3d layer into a 3d world composition (CompB).
I wanna match the relative position of Null-1 with Null-2
<a href="http://i1.creativecow.net/u/204103/kk.jpg"><img src="//i1.creativecow.net/u/204103/kk.jpg" border="0" /></a>
** LayerA and LayerB are comps.
Thanks a lot!
Darby Edelen
Re: Match a 2d comp null position with a 3d space comp null position.
on May 24, 2011 at 2:59:28 pm
If I understood the setup correctly, then this expression should work applied to Null-2's position property:
l1 = comp("CompA").layer("Null-1");
l2 = thisComp.layer("CompA");
p = l1.toComp(l1.anchorPoint);
l2.toComp(p);
Darby Edelen
Ismael Vega Trillo
on May 24, 2011 at 3:22:04 pm
It works very perfectly!
Well, not at all, it does the movement perfectly, but in a wrong position. I'm trying to get the movement over the surface of layer "Comp2" inside the composition "Comp3". In that way, I can get the same movement in a 3d space than the "null object" in the 2d composition.
Ismael Vega Trillo
on May 24, 2011 at 3:28:06 pm
l1 = comp("PTA").layer("Null 1");
l2 = thisComp.layer("PTA");
l2.toWorld(p);
With this change ("toWorld") it woks perfectly!!!
Thanks a lot man!!
Darby Edelen
on May 24, 2011 at 6:50:59 pm
Apologies, I misunderstood and thought you wanted a 2D composition location in the main comp. Glad you managed to make it work though! :)
Darby Edelen
Ismael Vega Trillo
on May 24, 2011 at 7:18:30 pm
No way! You have solved my problem!
Thanks a lot!
