Effect plugin
Brian Mills
Effect plugin
on May 18, 2011 at 2:07:53 pm
Hey all
What is the technique called that is happening at 45sec into this reel.
http://reelroulette.net/mikeflorio
The technique is the part where the record players are coming at the camera and cloning in a spiral.
Also what effect is used to do that...or is that just done manually?
Brian
Brian Mills
Re: Effect plugin
on May 18, 2011 at 2:08:47 pm
actually its about 47 sec in...
Brian Charles
Re: Effect plugin
on May 18, 2011 at 2:26:22 pm
[Brian Mills] "what effect is used to do that...or is that just done manually?"
Could be done manually or using expressions, or Trapcode EchoSpace.
http://www.redgiantsoftware.com/products/all/trapcode-echospace/
Brian Mills
Re: Effect plugin
on May 18, 2011 at 6:39:14 pm
Thanks for the suggestion...I didnt even think about Echo in time...that worked pretty good...:)
