Important Advice Needed compositing a video
Chris Lingard
on May 11, 2011 at 12:01:38 am
Hi my names Chris,
I am currently at Teesside Uni and I am trying to render out my final year project but I am having problems.
I rendered all my frames from Softimage using the HD 1280x720 res however when I try compressing all the image files in After Effects it speeds up my work making the whole scene not synced with my audio track anymore. In after effets i have been trying to render through Quick Time movie player running at 25 frames a second.
Any one got any suggestions on how this can be sorted? I am really struggling :(
Brian Charles
Re: Important Advice Needed compositing a video
on May 11, 2011 at 12:52:43 am
Sounds likely that After Effects is not interpreting the SoftImage footage correctly. Right-click on the footage in the Project pane and select Interpret Footage > Main. Then set the correct frame rate for the footage.
http://help.adobe.com/en_US/aftereffects/cs/using/WS3878526689cb91655866c11...
Walter Soyka
on May 11, 2011 at 1:33:08 am
One addition to Brian's solution: the default frame rate for imported image sequences is 30 fps. You can change this default under Preferences > Import > Sequence Footage.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Chris Lingard
on May 11, 2011 at 2:07:07 am
Thanks guys :)
