Line up keyframes to new fps
Kenneth Kennholt
on May 10, 2011 at 1:31:45 am
Hi.
I animated some solids based on a 30fps footage that i later changed to 24fp.
is there an easy way to get everything to line up to the 24fps footage?
Kevin Camp
Re: Line up keyframes to new fps
on May 10, 2011 at 4:00:36 am
Just changing the comp to 24fps should get you very close. After that I think you need to adjust them by hand if you need that kind of sub frame accuracy.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
