Dell M6600 Fiber Connection
COW Forums : SAN - Storage Area Networks
Jessica Muth
on Oct 24, 2012 at 7:34:06 pm
Hi everyone,
I am looking to see if there is an option for a fiber connection for a Dell M6600? Whether it is a docking station, adapter, etc.
Dell was of no help and didn't know what fiber was.
Any help would be greatly appreciated.
Jessica Muth
jmuth01@gmail.com
Alex Gerulaitis
Re: Dell M6600 Fiber Connection
on Oct 25, 2012 at 12:24:49 pm
Magma (and others, e.g. Startech) make ExpressCard-to-PCIe expansion chassis that a Fibre Channel card will likely work in.
Magma ExpressBox 1 ($829) is single lane PCIe 1.1 solution with a 2.5Gbs (250MB/s) bandwidth. Fibre Channel supports speeds higher than that, so the first question is, will that bandwidth of 250MB/s work for the task?
The second part will be to figure out if the Fibre Channel card will in that chassis. Generally it should.
Alex Gerulaitis
Systems Engineer
DV411 - Los Angeles, CA
Jessica Muth
on Oct 25, 2012 at 9:06:10 pm
I'm not sure about the speed, but I will take a look at your suggestion. Once I figure out the speed, I will post back. Thanks so much!
Jessica Muth
jmuth01@gmail.com
