10 gigE question for mac
COW Forums : SAN - Storage Area Networks
Paul mitchell
on Feb 25, 2012 at 6:40:05 pm
Hi guys
I'm considering hooking up two Mac pro towers via10 gigE cards to share 2 x internal raid 0's
My first is a 12 core Mac pro running Resolve with an internal 10 tb raid 0(5x2 tb)
The plan for the second is to be an 8 core 2008 mac pro to run Ultrascope with an internal raid 0 of 10 tb for a total of 20 tb
The plan is to have them connected to each other via 10 gigE cards
I'm looking at 2 x http://www.attostore.com/ethernet-adapters/fastframe-ns11.htm. ( one on each Mac pro)
Does anyone have any experience with this card?
I looked at small trees but they are more expensive
I only need single ports cards. I will only be connecting the two machines to each other. Therefore no need for dual port cards.
would there be another card for recommendation for this purpose
I'm also wondering how the raid from the second Mac pro will show up on my main computer,will it show as a mounted drive?
Any info would be greatly appreciated
Thanks in advance
Bob Zelin
Re: 10 gigE question for mac
on Feb 27, 2012 at 1:44:59 am
the ATTO NS11 card is fantastic. If you do not configure a server, you are creating a "push pull" enviornment for sharing files, you are not creating a shared storage enviornment.
Both the ATTO NS11 and Small Tree cards require a configuration on the MAC to get them to work at the correct speeds. By simply loading the driver, you will not achieve the maximum performance of either of these two cards.
The ideal situation is to stick a multiport ATTO card or Small Tree card into a server, and put all your storage on your server. Then put the NS11 or single port Small Tree card in your MAC client computers, and you can achieve what you really want to do (unless push pull files is all you really want). But again, without optomizing these cards for the MAC, you will not achieve peak performance.
Let me know if you have any more questions.
Bob Zelin
Paul mitchell
on Feb 28, 2012 at 6:07:07 pm
Hi Bob
Thank you so much for explaining the process, looks like I was way off in how I thought this process would work.
When you say " The ideal situation is to stick a multiport ATTO card or Small Tree card into a server, and put all your storage on your serve" , do you mean a multiple hard drive enclosure?
Could you give an example model of a server, around 20 tb for example
Which atto card would be suitable for this server
How does this " push pull" environment work as you mentioned
Thank you so much in advance
Bob Zelin
on Feb 28, 2012 at 8:42:01 pm
you use an external drive enclosure with your Mac Pro and an ATTO R380 or ATTO R680.
an example of a server is nothing more than an ATTO R380 or an ATTO R680 sitting inside a Mac Pro.
if you want more info, contact me at maxavid@cfl.rr.com
Paul mitchell
on Feb 28, 2012 at 9:00:40 pm
Hi Bob
Thanks again for the info
I've been doing some research, what do you think of the Stardom Sohoraid ST8 to go with the atto R680
Thanks in advance
Bob Zelin
on Feb 29, 2012 at 1:56:59 pm
The Stardom requires two cables to run the unit, which means no expansion. In the real world, you will run out of room. Without the ability to have some sort of SAS expander, so you can add chassis, you are buying into a dead end.
With the Stardom, that requires two cables to run all 8 drive slots, you do not even have the other port of the R680 to feed a second chassis in the future.
I believe I gave you my email, so you can contact me for more detailed answers.
Bob Zelin
Jeff Baker
on Mar 29, 2012 at 1:45:12 pm
Hi Bob, I just read your Maxx Digital testimonial and had them send me over a quote. I ended up feeling like someone who had accidentally waked into a Ferrari dealer intending to buy a Honda. My bad. I work at a small non-profit liberal arts college so I need to figure out the cheap way to do this.
We have 3 editing mac pro editing stations all in the same room, and I just want one of them to handle all the storage and hold all the video and video project files for the other workstations, and still be an editing station.
I was thinking a multi-port 10gb Ethernet card in that station, but don't know if I could just use the 1gb cards that come with mac pros or if they would need single port 10gb cards for them. I also need internet access for the machines, so does that mean I would need a switch, or could the 2nd Ethernet card in the mac pros handle that?
We edit with premiere pro, so we ingest avchd and P2 HD (720P30) footage and use it without transcoding.
I am about to order the third mac pro so any help would be appreciated so I know how to configure it if so (or if) we can use it as a video editing station and the primary video storage system.
Cesar Cabrera
on Jun 27, 2012 at 2:43:18 pm
Good morning. It is possible to install a small tree or atto 10gig E to already running Xsan with a Rorke Galaxy 3g and change the network from fiber to ethernet 10gig and leave the Galaxy and the server in fiber?
Steve Modica
on Jun 27, 2012 at 3:27:40 pm
[Cesar Cabrera] "It is possible to install a small tree or atto 10gig E to already running Xsan with a Rorke Galaxy 3g and change the network from fiber to ethernet 10gig and leave the Galaxy and the server in fiber?"
Not sure of the layout here. If the clients currently have FC cards, you'd have to switch them over to FCoE and purchase an FCoE switch to handle the conversion between the MDCs and the storage's FC ports. Cisco Nexus switches do this (that's what we use internally for development).
Steve
Steve Modica
CTO, Small Tree Communications
Cesar Cabrera
on Jun 27, 2012 at 9:28:08 pm
Thanks a lot! But we want to put the clients on 10gige and keep the the fiber protocol only between the xserve and galaxy. The clients we would like to have them on 10gige network.
Steve Modica
on Jun 27, 2012 at 9:34:12 pm
[Cesar Cabrera] "Thanks a lot! But we want to put the clients on 10gige and keep the the fiber protocol only between the xserve and galaxy. The clients we would like to have them on 10gige network."
I think you'd have to ask Rorke in that case. I'm not sure what they allow (in terms of protocols and performance) from their Galaxy box.
Steve Modica
Tim Ward
on Mar 1, 2012 at 2:32:45 pm
Paul, please give us a call or send me an email. I think we can help you out.
Tim Ward
http://www.small-tree.com
Bob Zelin
on Mar 4, 2012 at 6:22:15 pm
so Paul, what did you decide to purchase ?
Bob Zelin
Paul mitchell
on Mar 4, 2012 at 8:17:07 pm
Hi Bob
Thanks for the follow up
Right now I'm thinking of heading to NAB to check things out.
Also the rumors of a possible new Mac pro are interesting ,The new XeonE5 chips and new video cards, make this a possibility, if they do release them, they will most likely have thunderbolt, so that changes everything
Luckily I'm in no rush. This is for a home setup.
I'll see in a few months what develops and re-evaluate things
Andrew Richards
on Mar 5, 2012 at 3:32:52 am
[Paul mitchell] "Also the rumors of a possible new Mac pro are interesting ,The new XeonE5 chips and new video cards, make this a possibility, if they do release them, they will most likely have thunderbolt, so that changes everything "
I wouldn't be shocked to see on-board 10GbE in a new E5 Xeon Mac Pro. Now there's a USP for you!
Best,
Andy
Bob Zelin
on Mar 5, 2012 at 11:59:09 pm
excuse me Andrew, but what new Mac Pro ?
If you have proof of a new Mac Pro that you can show me, I will buy you dinner at the most expensive restaurant in Las Vegas during NAB that you can find.
Bob Zelin
Andrew Richards
on Mar 6, 2012 at 1:30:48 am
Same hints everyone else has. Drivers for AMD Tahiti GPUs in 10.7.3, E5 Xeons are reportedly "in the channel" and that means they will launch any day now. That is the chip Apple would be building a new Mac Pro around, if there is to be one.
There may not be one, and that would be a shame. So let me rephrase:
I would not be shocked if there is on-board 10GbE on the new Mac Pro, assuming Apple is making a new Mac Pro now that the new Xeons are imminent.
At any rate, we'll know well before NAB if there is going to be a new Mac Pro assuming the reports of E5 Xeons in the channel are true.
Best,
Andy
Andrew Richards
on Mar 6, 2012 at 10:16:22 pm
The new Xeons are officially launched.
Of particular interest from that article:
"In conjunction with the processor, Intel also announced the Ethernet Controller X540, a separate chip for 10Gbps networking. Intel projects that the chip will help make the faster networking an ordinary rather than premium feature."
Keep your eyes peeled...
Best,
Andy
Matt Geier
on Mar 8, 2012 at 12:16:48 am
HI Paul,
NAB will certainly prove to be a good time to see what vendors and other folks in the industry are doing.
I read this and wanted to ask...
Are you opposed to using RJ45 Copper (CAT6a) instead of SFP+ based adapters?
If you are leaning toward SFP+, perhaps you should equally consider RJ45 as an option since there are a few immediate advantages to running with CAT6a RJ45 connections now...if nothing else, just do so for anticipation of what will happen down the industry road later.
Connecting the two Mac Pro's with any Ethernet is the easiest part.
Getting them to work a certain way depending on what kind of environment you are trying to build long term will be the tricky part for you. I'm referring to building a Shared Video Editing (Real Time) Network vs just a more data center Copying / Sending Files Back and Forth (Push / Pull) Network.
-- Whichever one you choose, set up and the way it works after it's configured will vary depending on what was decided, but either one of them can be done very successfully with Ethernet 1Gb and / or 10Gb only environments, or along side an existing solution environment, like Fiber Channel for example.
So why 10GbE RJ45 copper vs SFP+ optical?
1: -- It's Twisted Pair copper, it's RJ45, it's what you have right now for your 1Gb ports on the Mac Pro's ---
This card option offers you 2 x 10GbE RJ45 ports for the ability to have a faster transfer take place to more then one 10GbE network, or link aggregate into a switch to serve multiple 1GbE clients, or some other low bandwidth needs on the network.
You may already have wired up copper in the facility anyway, and this would allow you to utilize the adapters you choose.
2: -- There's no performance gain or loss to running fiber light/glass vs copper twisted pair ---
In most of the cases, when it comes to choosing one or the other in terms of cost, copper runs save on money, are common in building directly to the desktop, and are usually whatever is between your desk and the wall and server room anyway.
3: -- Limitation of 1 port vs 2 ---
Imagine if you do so well with your networking of this, and now you need to add another Mac Pro with 10GbE, or some other 10Gb capable system.....great, but you don't have anything with another 10GbE port on it to use.....ho hum.....Now you may be forced to buy a very expensive $12K-15K ALL 10GbE based switch just to support the three of you on the same network....at minimum, if you decide to opt out of the switch, your 3rd system still needs a 10GbE connection, so you'll need to consider buying an additional, dedicated server, and an additional QUAD or SIX port 10GbE adapter just to get the three systems connected to the same network point to see one another.....
(now your savings up front.....just became an expense later in the future)
Final thoughts to consider....
I personally expect to see a higher port count Copper RJ45 10GbE Card come out and one that will be supported under Mac OS X....it would only be sensible since there are equally port count qualified 1GbE versions now.
The idea of being able to share and move data easily on a network is that you will in turn spend less time trying to get each other access to the data, and hence be more productive....in turn the increase productivity will institute new growth, and the new growth means the need for more connections as new people come in, more networking bandwidth, greater expandability, etc etc etc.......
Why limit yourself now with and upgrade of a single port / fiber Ethernet adapter, and instead upgrade now using a Dual Port RJ45 adapter and keep in mind your plan of growth later because you will use the extra port / or find a use for it....
Ultimately your growth depends on your dreams coming true in the future of your business? Why limit that if you don't have to?
Just my $00.02
Matt G
Paul mitchell
on Mar 9, 2012 at 12:00:51 am
Thanks Matt for taking the time to share your thoughts, and everyone that's contributed so far
You are correct with everything you've said, I'm still new and green to the world of networking so I don't know much about the different types of connections, etc
I'm a colorist
At this point I'm trying to put together a small, low budget, 1 person system. To run avid mc6, final cut, adobe premier, but mainly to run davinci resolve, no other person involved, people come to me with their projects on drives and then I just copy to my internal raid and work from that.
I Already have a 2010 2.93ghz 12 core with internal 10 tb raid 0 , 24 gb ram
And it runs beautifully, I can see myself running like this for a while, the system does everything I throw at it.
To maximize resolve's performance I'm getting blackmagic Ultrascope, to use instead of Davinci's internal scopes.
To do this, Ultrascope needs to run on an external Pc or another Mac, being a Mac guy I thought I would stick the Ultrascope Pcle card inside a 2008 8 core Mac, then I thought I could populate that second Mac with another 10 tb raid 0, i thought i could turn the second mac as an external raid, getting 2 birds with 1 stone to run Ultrascope and gain a second raid in one box, instead of getting a separate external raid box and card I would simply end up with 2 Mac towers
That second Mac would only be used to run the Ultrascope program and run the 2nd 10 tb raid 0
My idea was to then access the media off the second Mac from my main Mac , mainly DPX sequences, large files
I was hoping that I would be able to see the media as a mounted drive from within any application in my main Mac ,so I could load a DPX sequence and play it real time. 5 x 2 tb drives in raid 0 are fantastic for achieving HD DPX playback realtime
At this point I don't see myself needing more than 20 tb total of storage ( 2x 10 tb on 2 macs) once a job is done after some time goes by I just delete it if I need room, if for any reason a year later client wants something changed then they would bring their drives back
It's a 1 person operation or mini facility, that's why the 1 port only idea, only 2 macs needed
But it looks like I was way off in how it thought this process would work. In other words don't think this would work
So I'm thinking of waiting for a possible new macro with thunderbolt and then just get a thunderbolt external raid
And I'll run Ultrascope on a cheap Pc
We'll see what develops in the next couple of months, I'm ok waiting
Matt Geier
on Mar 9, 2012 at 6:15:46 am
Hey Paul,
Thanks for posting more info. My pleasure to share my opinion.
I think you should certainly stop by the Small Tree booth at NAB and see what you can see there.
DPX sequences can run in real time on Mac OS and equally on a Windows or Linux system as well, and do so over 10Gb Ethernet.
The bandwidth of 10bit sequences like DPX are in the area of 130-160 MB/sec per sequence.....10GbE is certainly the way to go if you want to work with Ethernet. I would start being careful about the choice of hardware to play the video out over the network then as well.
The real trick to getting it working to go real time, using uncompressed, all the time, and always being able to support "X" number of sequences concurrently.
Depending on your specific needs....maybe you only need 1 happening, or maybe you need 3 or more happening at once...
Personally I would not set my heart on being comfortable with the use of something like an internal software RAID configuration to get this working the way you'll expect it to either.
Software RAID configurations that I've been privy to, always add a lot of extra operating overhead to the operating system and the overall design of the configured system.
Software RAIDS tend to be inefficient for good, sustainable and reliable real time capabilities.......not saying something doesn't exists.....
I'd be curious to hear some other opinions on this software RAID idea and running uncompressed real time to see what they think, or if they concur.
I'm sure at NAB this year, you'll find the answer you're looking for.
I highly encourage you (and anyone) to stop at Small Tree's booth to discuss these types of topics. Ethernet is certainly viable for you.
I know some amounts of uncompressed video streams are supported on the new shared storage solution as well.
It runs a Linux based operating system BTW.....
I have no doubt you'll be impressed with the response you'd get!
I hear that the booth is going to be pretty spectacular this year as well!
I'm looking forward to watching this thread develop for you.
Thanks again!
Matt
Neil Sadwelkar
on Mar 27, 2012 at 3:28:47 am
So basically you needed another system to put your UltraScope in. And BM's spec said it needed to be a MacPro. So you thought if I'm using a MacPro why not let it do some storage too rather than just scope work.
Bear in mind the the UltraScope will also eat some CPU cycles, so no matter if you have 10GigE between the two MacPros, when the Ultrascope MacPro goes into 'server mode' when you run files off it, particularly DPX sequences, you may see some performance difference between UltraScope running or not.
A better bet is to use a cheap PC for the Ultrascope and a good SAS RAID for additional storage.
Neil Sadwelkar
neilsadwelkar.blogspot.com
twitter: fcpguru
FCP Editor, Edit systems consultant
Mumbai India
Paul mitchell
on Mar 28, 2012 at 2:06:51 am
Hi Neil
thanks for the information, I will get a PC to run Ultrascope alone
thanks again
