Problem when I login the iscsi hard disk
COW Forums : SAN - Storage Area Networks
irrani dam
on Nov 25, 2009 at 9:18:00 pm
We use CentOS 5.3. When I login the iSCSI hard disk, it show the below
information. I am confusing about this.
Anyone can give me a help~~~Thanks~~~
iSCSI Target: Microsoft iSCSI Software Target
iSCSI Initiator: iscsi-initiator-utils-6.2.0.871-0.10.el5
[root@localhost /]# iscsiadm -m node -p 10.6.64.140 -l
Logging in to [iface: default, target: iqn.1991-05.com.microsoft:wss-
iscsi-test1-target, portal: 10.6.64.140,3260]
Login to [iface: default, target: iqn.1991-05.com.microsoft:wss-iscsi-
test1-target, portal: 10.6.64.140,3260]: successful
Vendor: MSFT Model: Virtual HD Rev: 3.2
Type: Direct-Access ANSI SCSI revision: 05
SCSI device sda: 41943040 512-byte hdwr sectors (21475 MB)
sda: Write Protect is off
sda: got wrong page
sda: assuming drive cache: write through
sda: got wrong page
sd 6:0:0:0: Attached scsi disk sda
sd 6:0:0:0: Attached scsi generic sg0 type 0
Regards,
Irrani
