Panasonic G80/85 Dual IS 2
COW Forums : Panasonic Cameras
Abraham Cohen
on Jun 21, 2018 at 8:16:32 pm
Panasonic G80/85 has a Dual IS 2. It is the only ILC that has this technic, Pana didn't continue this : it proceeds with Dual IS "1" .
So if you don't own the lens that is compatible with Dual IS 2 does this mean you only use the 5 axis is in the G80 body? No Dual IS "1" available there?
George Austin
Re: Panasonic G80/85 Dual IS 2
on Aug 30, 2018 at 10:13:20 pm
It's a little hard to parse the barely translated text, but All lenses compatible with Dual I.S. 2 are backward compatible with original Dual I.S. bodies: http://av.jpn.support.panasonic.com/support/global/cs/dsc/connect/dual_is.h...
Also, the G9 and GH5 also support Dual I.S. 2 - the G80/85 isn't alone!
