New HLG profile in firmware 2.0 example
COW Forums : Panasonic Cameras
Duke Sweden
on Sep 28, 2017 at 1:31:30 pm
I've since read you shouldn't use HLG unless you plan on rendering to HDR, but it does get some interesting results. On the left is graded V Log, on the right, graded HLG (which really looks bad without color correction/grading).
My skin on the V Log side is pretty much what I look like. On the HLG side, however, I look like the Snake Man from a circus sideshow, and as realistic as that looks, I am in no way that weathered. Life long sea captains don't look that bad! Anyway, just putting this up as an example of the differences between V Log and HLG.
Dell XPS 8920
Intel i7 core 7700 build
GeForce GTX 1050ti
32 Gigs of RAM
3 7200 RPM SATA Drives
Windows 10 64-bit
Premiere Pro CC 2017 v.11.0
Chris Wright
Re: New HLG profile in firmware 2.0 example
on Sep 29, 2017 at 1:11:54 am
i was reading and seeing that HLG gets muddy in shadows, so if you use it, you need two things:
1. a mostly high key shot with almost no shadows
2. hlg is not made for skin, mostly buildings/landscape shots
its just too crunchy in dynamic range without RAW imho. vlog is the best.
also, you need a separate lut for its contrast range. I'm not going to even
bother with it because almost no one has a hlg tv. it doesn't help dynamic
range. if anything, the muddyness makes it worse.
Duke Sweden
on Sep 29, 2017 at 10:02:09 am
Oh, come on. Please? 😉
Thanks for that info. I was feeling a bit guilty not using this new picture profile, but I can see that, obviously, V Log is much better for what I do.
I'll get those other samples to you. My back has been killing me so I haven't gone out much with the camera these last few days.
Dell XPS 8920
GeForce GTX 1050ti
32 Gigs of RAM
Windows 10 64-bit
