DVX200 2-Slots Func Fail
COW Forums : Panasonic Cameras
Ken Bennett
on Nov 13, 2016 at 3:14:38 am
On my new DVX200 I have the record function set to "2-Slots Func" - "Relay Rec" but when card 1 fills up it flashes "Card Full" and stops recording. Never switched to card 2. I'm shoot FHD 1080/59.94p 100M. Card 2 new a new card.
Why isn't this working correctly? What do I have set wrong?
Thanks.
Ken Bennett
Video Adventures
Capturing Your Life's Adventures!
Bernie Mitchell
Re: DVX200 2-Slots Func Fail
on Jan 26, 2017 at 10:40:35 pm
Ken
Make sure both cards are the same. Class and speed.
If you have relay set in the record function then it should work
Bernie
Lindsay Simpson
on Jul 19, 2017 at 2:06:48 pm
I have experienced this same issue with my DVX 200. I am using 2 duplicate cards (Speed and Brand) and I have the camera set to relay record. It will not automatically switch cards. I must enter hte menu and manually switch to the next slot.
Josh Malyn
on Apr 16, 2018 at 9:47:57 pm
I was wondering if anyone has solved the problem with the DVX200 in relay mode not working with the two cards. I'm using SanDisk Extreme Pro 95/MB/s 128 GB SDXC cards and had the same problem. It just blinked "card full". I thought maybe it was the fact that it was a SDXC card.
