P2 Cards, Can you use a E - Series and a R - Series in the same Camera?
COW Forums : Panasonic Cameras
Dean Kubasek
on Aug 11, 2016 at 8:58:26 pm
Just recently got a HPX-170, and was wondering if you can you use a E - Series in one slot and a R - Series in the other without problems?
James Dow
Re: P2 Cards, Can you use a E - Series and a R - Series in the same Camera?
on Aug 12, 2016 at 7:14:42 pm
I'm pretty sure that you can NOT mix Series E and Series R P2 cards.
JPD
Dean Kubasek
on Aug 13, 2016 at 8:00:54 am
I kinda thought so, Thanks for the info!
Dean Kubasek
on Aug 13, 2016 at 7:30:33 pm
Sorry for the very beginner questions, But is it a problem to run a set of Two R series, And then a set of two E series once those are full? Or is it important to stick with one series all the time?
Thanks for your help
Dean Kubasek
James Dow
on Aug 16, 2016 at 3:35:54 pm
No, that is fine. That's what I do.
JPD
Patrick Donegan
on Oct 29, 2017 at 1:11:42 am
Have you attempted to mix the card types y et?
I don't see any tech reason why it would not work.
FCP X 10.2.3 - user since FCP 1.25
iMac mid 2011, MBA mid 2012
iPhone 4
HVX-200, Shure wireless mic
Miller Solo tripod
Advanta-Jib
