Damaged/ripped DVCPro HD tape - best way to capture/re-lay
COW Forums : Panasonic Cameras
Ian Liuzzi-Fedun
on Aug 24, 2012 at 11:43:21 pm
I have a ripped DVCPro tape that I want to capture and then re lay back to tape. I can manually repair the tape however I am torn between capturing in DVCPro HD or through the SDI output of the deck to my capture card and then real-time transcoding to ProRes. I know at the end of the day only the most technical and sensitive will be able to tell but since this is supposed to be a master, I want the best quality possible. Would capturing as ProRes give me an more latitude and help with compression concatenation or not?
