Ripped dvcpro tape
COW Forums : Panasonic Cameras
Ian Liuzzi-Fedun
Ripped dvcpro tape
on Jun 24, 2012 at 11:49:42 pm
I have a dvcpro tape that ripped as I was pulling it out of our camcorder. I need to repair it. In the past I have just taken scotch tape and while I get a hit at that moment i can still recover the tape. Is there a better way to do this?
Noah Kadner
Re: Ripped dvcpro tape
on Jun 25, 2012 at 4:50:41 pm
Most post houses can do this for a fee- just depends where you are in the world.
Noah
Call Box Training.
Featuring the Panasonic GH2 and Panasonic AC160/130.
Chris Tompkins
on Jul 27, 2012 at 1:17:50 pm
I'd take care of it the way you have been.
Chris Tompkins
Video Atlanta LLC
Ian Liuzzi-Fedun
on Aug 24, 2012 at 11:43:47 pm
As a follow up:
I am torn (no pun intended) between capturing in DVCPro HD or through the SDI output of the deck to my capture card and then real-time transcoding to ProRes. I know at the end of the day only the most technical and sensitive will be able to tell but since this is supposed to be a master, I want the best quality possible. Would capturing as ProRes give me an more latitude and help with compression concatenation or not?
Chris Tompkins
on Aug 25, 2012 at 1:04:22 am
IMO, b/c it originates on DVCPROHD, you would not gain any noticable difference coming in via SDI to Prores. Unless;
You were planning on many, many layers of grfx and rendering and compositing and more layers, multi-rendered etc.
JMO
Chris Tompkins
Video Atlanta LLC
Ian Liuzzi-Fedun
on Aug 25, 2012 at 1:14:45 am
My thought exactly but they say you loose some with every generation so I am wondering if you loose less with transcoding to a better format.
