NEXTO devices
COW Forums : Panasonic Cameras
chris magid
NEXTO devices
on Mar 15, 2011 at 3:41:33 pm
Anyone using a NEXTO NVS 2525 for P2 use and care to share their experience?
Can it run off AC as supplied with accessories in the base kit from the manufacturer?
Does the cigarette lighter / charger come with?
Anyone upgrade the internal drive to larger capacity?
Is there a make and model of external eSata or USB drive that you like to use with your NEXTO?
Figure for maximum speed esata is the way to go, but I haven't found too many 2.5 inch external eSata drives.
Chris Magid
RTVF
chris magid
chris@gortvf,com
Renaissance Television & Film
http://www.gortvf.com
Dale West
Re: NEXTO devices
on Mar 18, 2011 at 10:36:14 am
I have on. It might be one of the first delivered by able cine. There are things I love about it and other things not so much. I bought whole package. 750 gig internal and 750 external drives and all the extras.
Things I like:
1 really fast if you don't verify. I still use P2 CMS but there is also a preview function that allows you to look at the video on the screen. AVCIntra is not totally supported (the video is not smooth) but I hear that there are firmwarenupdates in the works
2 Fairly easy to use. There are some processes that are not intuitive but once you get used to them then it's very easy to use
Things I'm not in love with:
1: And this is the biggest issue I have. The external drive is esata p. That is the biggest gripe I have. I bought a g-tech 2tb drive and figured that this was going to be perfect. Wrong. The external drive to be used with the esata has to take it's power from the esatap port. If you try to power with a power supply it will not work.
2: The device names the file with the date and a sequence number. The first file will end in .000 the next will end in .001 and so on. We normally name the files but found that if we are going to continue to do that we have to wait for all the files are in.
I've found a supplier of drive enclosures and you can get drives at compusa, but if Lacie or G-tech made mini esatap drives that would rock
I hope to see the Nexto folks at NAB and talk about the 2525. I hope they are willing to listen to some of my comments. In general it is a very good tool. I was going to purchase the Panasonic unit but my understanding is that it does not make a duplicate copy at the same time
The other thing is I'm still learning how to use it.
I hope that answers some of your questions. If you have more you can contact me off list at. dale@dalewestvideo.tv
Dale West Video
North Miami, FL
305-588-2683
chris magid
Re: NEXTO devices
on Mar 18, 2011 at 2:29:11 pm
Well. They do make esataP to sata cables.
Was planning on using something like that to allow the use of raw internal laptop drives as the external drive with Nexto. Keep them in a sleeve and other protection when they aren't in use. Pretty cheap too.
What do you mean it renames files? Is it assigning folder names or actually renaming P2 camera files? That would be a little odd. Not exactly a straight copy.
I looked at the panasonic unit too, which requires a SSD for internal use. Large SSDs are over $2,000.00.
Chris Magid
RTVF
chris magid
chris@gortvf,com
Dale West
Re: NEXTO devices
on Mar 19, 2011 at 10:43:30 am
What I mean about the file name is that the device simply does a date sequence. A file today would be 20110319.000. The next one would end in .001 and so on. What we do if we are shipping the drive to the client is rename them when they are on their drive. You know: interview with so and so. B-roll of such and such. We are lucky enough to have a bunch of cards and with the nexto we find we can rotate the cards with every venue or situation change. The nexto is fast enough so we don't usually have to worry about card availability. I suppose its just because that's how I used to label tapes. I have an inverter in my van and we will offload between locations and on the way home or at our video village if we are in the same place all the time. Units like this really help take care of the media management issue we old dogs have had with cards of any style. I also use it for SxS and the compact flash adaptor is really handy if someone is doing DSLR work. I understand that they are making an Alexa version of the Nexto as well.
Restating my dislike is the fact that for the fast copy to an external drive has to be esatap. You can sync using FireWire 800 or USB 2. But direct connect to external HDD has to be with the esatap.
One has to wonder if thunderbolt is going to throw all of this into a spin
Dale West Video
North Miami, FL
305-588-2683
Jeff Regan
Re: NEXTO devices
on Mar 21, 2011 at 10:53:22 pm
We have the Panasonic MSU10 with a 500Gb drive, not SSD. This is what came with the unit. This is a very simple device to use, but does not deal with any cards other than P2, does not playback clips, does not transfer to two drives at the same time.
It does do data verification, if wanted, but will slow down transfer. Optimally, with an internal SSD, verification off, it will do 4x transfers.
It is good for rental because it is so simple to use, but limited to P2 only, as noted earlier and no playback is unfortunate--just thumbnails.
Jeff Regan
Shooting Star Video
http://www.ssv.com
chris magid
Re: NEXTO devices
on Mar 21, 2011 at 11:00:08 pm
Is the traditional hard drive slid into the unit via the tray?
Panasonic's marketing materials are not good as they seem to make it look like the only way to use a traditional hard drive is externally. Some materials even say not to use a HDD internally.
Yet on their site they seem to sell trays for HDD.
Very confusing and they just lost a sale because of it.
We would of bought. Went with the Nexto instead. Will report back.
Chris Magid
RTVF
chris magid
chris@gortvf,com
Jeff Regan
Re: NEXTO devices
on Mar 21, 2011 at 11:27:45 pm
Chris, yes, SSD and HDD. It is confusing on Panasonic's own site. There is a pre-configured SSD model, and an HDD model, as well as an empty model.
It definitely will transfer from a P2 card to an external HDD in Host mode. HDD must be under 2TB.
Jeff Regan
Shooting Star Video
http://www.ssv.com
Jeff Regan
Re: NEXTO devices
on Mar 22, 2011 at 12:43:35 am
Just a couple of notes after some testing of the Panasonic MSU10:
I was able to transfer, via P2 E card, a 16 min. AVC-Intra 100 1080/30PN set of clips to the internal drive with data verification off in 3:00, which is 5x real time.
Same clips with data verification on took 8:30, or a bit slower than 2x real time, similar to MacBook Pro with ShotPut Pro, data verification on using PCD20 via FW800 to two FW800 ext. HDD.
Using the internal 500Gb HDD removed from the MSU10 with dual USB cables into MacBook Pro took 6:35 with the same footage.
Tried to use the MSU10 in host mode with eSata drive, but didn't work.
Tried to use MSU 10 in hose mode with same drive via USB, device not recognized. This is most likely due to Mac OS formatting. Have to try a PC formatted drive next.
Jeff Regan
Shooting Star Video
http://www.ssv.com
chris magid
Re: NEXTO devices
on Mar 22, 2011 at 3:17:03 am
Thanks for the info.
I'll test my arriving Nexto and pass on numbers.
Chris Magid
RTVF
chris magid
chris@gortvf,com
Joseph Kim
Re: NEXTO devices
on Apr 6, 2011 at 2:33:38 pm
Hi, Dale
Thanks for your post.
There are few things I would like to mention.
(1) eSATA vs Powered eSATA:
eSATA port designed to be used with faster speed but it has a limitation that only carry data, but not power. This is standard specification of eSATA.
NVS-2525 supports eSATAp host (powered eSATA or power-over eSATA). eSATAp is designed for portable hard drive with full advantage of speed and carry power in a single cable.
If you connect your gtech 2tb hard drive with computer, you would also need two cables attached (one for data & the other one for power, maybe via USB) or one cable attached to gtech and plug-in ac adapter to power
So, this is not a limitation of Nexto device.
NVS-2525 bundled with an external eSATAp hard drive (750GB), so you can start make two identical copies straightway. If you want to get 2nd drive, you can buy delock enclouser (model id: 42465 ) and a SATA (2.5"/SATA/7200rpm) hard disk. or you can buy Seagate GoFlex Pro 7200rpm (model STAD750100) and a GoFlex upgraded powered cable (model: STAE103).
(2) Nexto device doesn't change names of original video files.
After successful copies, you will see FOLDER names that is form of "20110405"(date of video taken) and followed by "." (dot) then 000 (sequence no). If you have several cards that shot on same day, then 2nd card will be 20110405.001 then 20110405.002 and so on.
Inside that folder, you will see all original files and these are exactly same names of SxS or P2 card's contents.
Nexto NVS can also generate "INDEX.htm" file after each successful backup, so you can identify each backup by opening "INDEX.htm" under the root directory later on, in the edit room. It displays (single frame) clip view with meta data. This is very useful for editor.
You can either activate "AUTO GENERATION INDEX" function on or off under MENU.
(3) Advantages of purchasing NVS-2525 for P2/P2E users
- Portable and Rugged design (154 x 91 x 33 mm, 430g)
- Make two identical copies simultaneously (MCopy)
- Copy (80Mb/s), Verify (86Mb/s), Mcopy (76Mb/s)
i.e. a 32GB P2E card in 'minutes' 'seconds': 7'24" to copy / 7'24" to verification / 7'01" to make two identical copies onto internal and external.
- Versatile Power management; internal battery can be rechargeable by ac adapter, AA battery holder (4x AAs), external Li-poly battery pack, car charger or interface cables(FW800, USB2).
- offloading from various cards, SxS, SxS-1, P2, P2E, CF
- Cost effective
NextoDI, Inc will be at NAB 2011, Booth # C11723. Come to see us!
NextoDI, Inc NAB site
Thank you and hope this information helps.
Joseph
Nexto DI UK
http://www.nexodiuk.com
Dale West
Re: NEXTO devices
on Apr 11, 2011 at 10:29:54 am
Joseph
Picked up a seagate drive and adaptor over the weekend. Ran a test and Perfect. Just what the Dr. ordered. Now I can maintain a safety copy and still send my client along his way with his own drive. For us in our run run run world, pointing out that drive to us was huge. Now by the time we finish striking we are truly ready to part with the client and everyone has everything they are supposed to have.
Just a quick question. Firmware updates? Was wondering what the plan is for AVC Intra. I tend not to show my client the screen when we shoot AVC Intra but instead hook up P2CMS since its a bit smoother on playback.
Was hoping to see you at NAB but work got in the way. Cant wait to see what else is on the way.
best
dw
Dale West Video
North Miami, FL
305-588-2683
Joseph Kim
Re: NEXTO devices
on Apr 6, 2011 at 1:35:28 am
Hi, Chris
The NVS-2525 comes with 'base package' and 'Plus 1 Pack'.
Base Package:
Main unit, Firewire/USB/Car charger cables,AC adapter, AA Battery Holder, Manual
Plus 1 Pack: External HDD(750GB), ESATAp cable, CF Adapter, External Battery Charger & cable, Leather Holing case(for HDD), Carring bag
The internal rechargeable battery can be recharged by AC adapter, car adapter, interfaces cable (Firewire800 /USB2), AA battery pack or external battery pack.
The internal hard disk is 750GB (SATA, 7200rpm) and you will be void manufacturer warranty if you disassemble the device. You should always consult your supplier or country distributor for a warranty repair.
The plus 1 Pack bundled with an external eSATAp (powered eSATA) HDD (750GB), so you won't need to buy additional external hard drive separately. If you want to purchase another drive, then I recommended you to look at Seagate goFlex PRO 7200rpm (Model STAD750100). Since Seagate use an unusual shape of cable, you should also purchase an upgrade cable, eSATAp (powered eSATA, Model STAE103).
Hope this information helps.
Joseph K
Nexto DI UK
http://www.nextodiuk.com
chris magid
Re: NEXTO devices
on Apr 8, 2011 at 2:54:51 am
Joseph,
GREAT PRODUCT!!!
I have been using my NEXTO`for a few weeks. It is very flexible and a great option for backing up cards in the field.
Only comment I could possibly have is regarding having to cable the external drive. Would be great if there was some sort of sliding dock like the Panasonic P2 stuff.
We actually use raw 2.5 drives externally (in a temporary enclosure which exposes their regular SATA and SATA POWER connections. Was able to find a esataP to traditional sata & sata power cable.
Small bump. Rest has been smooth sailing.
I'll check out the drive you recommend.
Thanks for a good product!
Chris Magid
RTVF
chris magid
chris@gortvf,com
Joseph Kim
Re: NEXTO devices
on Apr 10, 2011 at 7:24:35 am
Hi, Chris
It's really good to hear that you're happy with Nexto NVS-2525.
Thanks for the suggestions and I've forwarded it to NextoDI.
NVS devices have been designed to be most flexible, fast, reliable and also cost effective but keep in portable design. The product dimensions and weights are 154 x 91 x 33 mm / 430g with HDD.
In this sense, you'd probably agreed why NVS comes with an internal hard disk instead of user swappable hard disk.
Many thanks,
Joseph K
Nexto DI UK
NextoDI Manufacturer's website
Official distributor for UK and Ireland
Find out your country (local) distributors, here
Adam Foskey
Re: NEXTO devices
on May 12, 2011 at 4:00:23 pm
Hey Chris,
As far as ESATA goes with the NVS2525, I found it is a lot glitchier and touchy, meaning it can easily be bumped and stopped downloading or have a hard time downloading all the way through without finding an error. The only time I used the ESATA was for when we were syncing. Also, multi-copy can be very problematic at times, so i definitely recommend single copies if in a rush and have a lot of footage to download.
And in terms of the accessories and running off AC power all the above you mentioned are true. The cigarette adapter worked fine, AC power was the best and i recommend being on it anytime you have the ability to use it because it takes a while for the Nexto to recharge.
G-raids worked wonderfully with the NVS2525. But I haven't heard of anyone complaining about any other hard drive or ESATA not being really compatible with the device. All in all, I loved the Nexto. I had to use it while doing an on the road for a month, constantly moving shooting all the time TV/Documentary, and it never gave me problems, and made downloading at night much easier!
Hope this helps.
Adam
Joseph Kim
Re: NEXTO devices
on May 24, 2011 at 4:57:53 pm
Hi, NextoDI released new firmware (V1.11) for NVS-2525 (not Udf special). You can download free from http://www.nextodi.com/support/view.php?bbs=en_download&id=68
The manufacturer told me it will improve compatibility with external eSATAp.
Thank you,
Joseph
