HDX 900 suitable shutter speed?
COW Forums : Panasonic Cameras
Simon Cox
on Aug 23, 2009 at 6:10:50 pm
In a couple of days I'll be shooting with a HDX 900 in 1080-50i, 25P for broadcast in the UK.
I'm slightly confused by the 'System Mode' & 'Camera Mode' settings within the 'System Settings' of the Main menu.
I've set the 'System Mode' to 1080-50i and the 'Camera Mode' to 25P. Is the 50i referring to 'Interlaced'? By switching the 'Camera Mode' to 25P I presume I'm shooting in Progressive.
How does this affect the shutter? should it be off or set to a 'Half'?
I'm more used to cameras where I set to progressive and then switch the shutter to a 50th.
Any advice appreciated. Subject matter by the way is people climbing trees in a forest so no high speed required.
cowcowcowcowcow
Ernie Santella
Re: HDX 900 suitable shutter speed?
on Aug 24, 2009 at 3:01:01 pm
In 1080 mode, the camera will actually record interlaced. The 25p is framerate. What happens is, the camera records to tape at 1080/50i and adds the 25fps pull-down automatically. And yes, set the shutter to 'half' to get an accurate film/shutter look.
Ernie Santella
Santella Productions Inc.
http://www.santellaproductions.com
cowcowcowcowcow
Robin Probyn
on Aug 25, 2009 at 5:14:06 am
Yes a bit confusing when you first use HDX or Varicam..
The half shutter means its giving you a 180 degree shutter angle for what ever you have set the camera for... ie a half.. so at 25p half shutter is 1/50th.. just saves you having to work it out yourself.As far as i know anyway !!
And in theory replicating a film camera.. sometimes I,ll switch it off if I need a bit more stop.. as long as not alot of action in the scene its fine..
Ernie Santella
on Aug 25, 2009 at 5:49:05 am
I 2nd that. I switch it off once in a while too for the extra stop.
Ernie Santella
Robin Probyn
on Aug 25, 2009 at 5:52:58 am
Something that cant be done on a film camera!
Ive being setting the gamma to .55 a fair bit these days.. do you phutz with gamma much?
Simon Cox
on Aug 26, 2009 at 9:52:45 am
Many thanks,
That confirmed what I thought. Did the shoot yesterday and all seemed to go well.
Ta for the help.
Simon
Robin Probyn
on Aug 27, 2009 at 1:21:51 pm
Glad it went well... HDX900 is a good swissarmy knife camera.. good for freelancers.. and way cheaper than F900R... you can also shoot slo-mo in 720p mode ie shoot at 50p for 25p
Simon Cox
on Aug 28, 2009 at 4:24:36 pm
I quite liked the camera but the viewfinder is not my favourite. Mind you I'm not keen on the one on the 750 /790 always seems a tadge milky to me. Might be that the Hire Company have put on a cheaper one but I doubt it.
Hopefully I'll get chance to try the 720p slo mo at some stage.
Robin Probyn
on Aug 28, 2009 at 10:45:33 pm
Yes totally agree about the viewfinder... one drawback..
