Bands of diagonal noise
COW Forums : Panasonic Cameras
Mark Renz
on Apr 8, 2009 at 5:39:12 pm
We have 5 of the AJ-HD27FP Varicams. Two of them record what appears to be horizontal bands of diagonal noise throughout the image. Has anyone else seen this problem?
john sharaf
Re: Bands of diagonal noise
on Apr 8, 2009 at 5:44:09 pm
Marc,
This is not normal. Can you tell if it's the camera head or recorder (Visible in VF?). In any event these units need to go back to Panasonic, but make sure to send them a tape with fault on it.
JS
Mark Renz
on Apr 8, 2009 at 5:48:40 pm
The shooter says he hasn't noticed this in the viewfinder. It only seems to come up after reviewing recorded material. On one instance we were recording directly to FCP using the HDSDI out. It was never recorded to tape and it showed the same problems.
john sharaf
on Apr 8, 2009 at 6:10:20 pm
Because Varicam is a digital camera, it's less susceptible to "ground hum", but this effect could still be introduced by monitor connected to AC and/or analog audio connections. See if you can reproduce the effect with no monitor or audio connected before sending in to Panasonic.
JS
