Tapes to high res .mov files
COW Forums : Panasonic Cameras
Robin Probyn
on Mar 27, 2009 at 12:37:37 am
Hi all
had a question from a director.. he has shot most of his doc on the RED camera... I,ll be using my HDX900... he is asking how to get the tapes to high res .mov files ??
Ernie Santella
Re: Tapes to high res .mov files
on Mar 27, 2009 at 3:06:15 pm
Simple, your footage needs to be captured/digitized into a computer like Final Cut Pro. Once it is captured, it will be in MOV format. You do need to discuss with the Director and Editor as to what compression format, frame size, they would like when the footage is digitized. That will depend on what format the Editor will use in his editing.
Everyone needs to be involved in discussion, especially when different shooters, editors and cameras are used.
Ernie Santella
Santella Productions Inc.
http://www.santellaproductions.com
Robin Probyn
on Mar 29, 2009 at 5:34:10 am
Hi Ernie
Ok thanks for your reply.Just out of interest... what do the players rent for.. presuming cheapest model to use for digitising only.
Thanks again
Ernie Santella
on Mar 29, 2009 at 4:45:02 pm
I'm not a Red expert, but that camera records to either a hard drive or solid-state media, not tape, so no videotape deck is needed. You need some way to get those files (wavelet codec) into an editing system to convert to MOV files.
Ernie Santella
Robin Probyn
on Mar 29, 2009 at 11:08:28 pm
I,ll be using my HDX900... he has been using the RED previously .. so he,ll need a deck to digitise when he gets back to his edit.
