HVX200 matching with Varicam
COW Forums : Panasonic Cameras
Ryan O'Halloran
on Jan 29, 2009 at 7:53:24 pm
I am doing a two camera shoot. Varicam -A, and HVX -B . Any suggestions how to make them best match? The varicam is set to 30fps and as a standard shoots 720p60. Should I set the hvx to the same 720p60 and under the FILMCAM setting set it to shoot 30fps? Or should I just set the hvx to shoot at 720p30n?
john sharaf
Re: HVX200 matching with Varicam
on Jan 29, 2009 at 9:02:53 pm
The first principal of "matching" two cameras is to set them at the same frame rate and scanning standard. This presumes you want them to look alike, not different, so if Varicam is shooting 30p, then set the HVX to do the same.
Next would be to try and match the gamma curves, so that if the Varicam is in Film Rec 200% Dynamic Range, the most likely match would be one of the Film Look settings on the HVX. This is a guess, the only way to determnine would be to look at a chip chart with both cameras and adjust the various gamma tables while observing on a waveform. This will optimize the luminance match (shades of gray).
Then as for color, using a Chroma du Monde or similar color chart and the vectorscope, you'd want to adjust the matrixs to match.
Short of these efforts, set the cameras at same frame rate, white balance, black balance and shoot.
Good luck,
JS
Ryan O'Halloran
on Feb 2, 2009 at 4:40:41 pm
