Frame Rate Conversion
COW Forums : Panasonic Cameras
Michael Manfredo
on Jan 17, 2009 at 11:04:49 pm
Hello,
I am currently trying to convert some footage I shot at 60fps using Panasonic's frame rate conversion plug in. In the past, I used a 1200a deck and it was on fcp 4.5. The deck was connected via firewire. Now I'm on FCP V.6 and I am using a 1700 deck that is connected to my FCP system via sdi and it is going through a kona 3.
Any information would be much appreciated,
Michael
Noah Kadner
Re: Frame Rate Conversion
on Jan 18, 2009 at 7:55:12 am
AFAIK that plugin will only work with Firewire captured footage. The pulldown flags don't come across an SDI connection.
Noah
Check out My My FCP Blog and my new RED Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color.
Now featuring the Sony EX1 Guidebook,
DVD Studio Pro and How to Light Interviews.
http://www.callboxlive.com
gary adcock
on Jan 18, 2009 at 5:39:32 pm
[Noah Kadner] "AFAIK that plugin will only work with Firewire captured footage. The pulldown flags don't come across an SDI connection. "
Not true.
AJA's products do allow for RP188 to stay embedded when capturing as DVCPROHD( only)
AJA's toolset also allow for direct removal of flagged frames on HDSDI capture to ANY codec supported on the card when using the correct capture settings.
The description for this is in my IoHD article here on the Cow (listed below) but covers all AJA products.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD
http://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
Michael Manfredo
on Jan 18, 2009 at 8:30:18 pm
Hello ,
Thank You so much. The conversion happened through sdi but only to 29.97 or 23.98, not 59.98. I'm going to take a look at the article you referred me to, but first I wanted to send my gratitiude.
Thanks again,
Michael
Mike Zimbard
on Jan 19, 2009 at 3:23:31 am
That conversion plug-in is now part of FCP. Set your Kona FCP easy setup to be 59.94 Varicam DVCPROHD. After your clip is captured, click on it and then select "Tools>DVCPROHD Frame Rate Conversion...." From there you can pick the frame rate you would like to turn the clip into. Hope this helps.
Peter Corbett
on Jan 26, 2009 at 1:39:11 am
Does this also work if you capture playback via HD-SDI directly from the Varicam (as against a deck)?
Peter
Peter Corbett
Powerhouse Productions
http://www.php.com.au
gary adcock
on Jan 26, 2009 at 2:40:27 pm
[Peter Corbett] "Does this also work if you capture playback via HD-SDI directly from the Varicam (as against a deck)? "
Yes,
but a caveat....
The IoHD can do this all day long without issue due to the fact it can read both the LTC and the RP188 TC at the same time.
When capturing direct from the camera and trying to remove pulldown from a live stream with a Kona Card there are a couple of issues.
1) because the card in your computer needs to understand where frames are being removed, when there is NO hard in and out points set - it will need to guess when to end the clip and cease deleting the flagged frame when you hit stop.
This can cause the final few seconds of your capture to NOT have the flagged frames removed when working with Kona Cards - since the computer cannotpositively determine what to remove since there is no LTC- increase the capture length by 5-10 seconds and that should allow the computer to handle the content.
2) some people think this is a replacement for getting a deck-NO- remember that without LTC stream that can be captured from the IoHD - all of your Kona Card captured clips will start at 00:00:00 (or your default)
gary adcock
Studio37
Peter Corbett
on Feb 6, 2009 at 5:31:38 am
Thanks for that Gary. Much appreciated
Peter Corbett
